Displaying signaled LSP status information
The user can display status information about signaled LSPs for which the device is the ingress LER as shown in the example below.
device# show mpls lsp
*: The LSP is taking a Secondary Path
Admin Oper	Tunnel	Up/Dn Retry Active
Name	To	       State State Intf	 Times No.	Path
t1	  10.3.3.3	 UP	   UP*	  tnl1	 1	    5	  v2
The show mpls lsp detail command displays detailed information about a specific LSP. To display detailed information about the status of the LSPs for which the device is the ingress LER, enter the show mpls lsp detail command as shown in the example below.
device# show mpls lsp detail
LSP t1, to 10.3.3.3
 Path selected: pathsecondaryb, mode: manual revert-timer:
 Path selected is up for 3 seconds for the latest instance, traffic will be switched to it in 7 seconds.
 From: 10.2.3.4, admin: UP, status: UP, tunnel interface: tnl1
 Times primary LSP goes up since enabled: 1
 Metric: 1, number of installed aliases: 0
 Maximum retries: 0, no. of retries: 3
 Pri. path: dir, active: no
  Setup priority: 7, hold priority: 0, ipmtu 1400
  Max rate: 0 kbps, mean rate: 0 kbps, max burst: 0 bytes
  Constraint-based routing enabled: yes
  Tie breaking: random, hop limit: 0
 Sec. path: v2, active: active
  Hot-standby: no, status: up
  Constraint-based routing enabled: yes hop limit: 0
 Active Path attributes:
  Tunnel interface: tnl1, outbound interface: e1/1
  Tunnel index: 5, outbound label: 1966
  Path calculated using constraint-based routing: no
  Explicit path hop count: 1
   10.10.10.2 (S) -> 10.20.20.2 (S) Recorded routes:
  Protection codes: P: Local	N: Node	B: Bandwidth	I: InUse
   10.10.10.2 -> 10.20.20.2
