To configure a maximum IP packet size for an LSP, complete the following steps.
Enable the device for configuration.
Enable the MPLS router.
device(config)# router mpls
enable and configure the label switched path (LSP).
device(config-router-mpls)# lsp tunnel1
In this example, the LSP specified name is
tunnel1.
Configure the IP packet maximum transmission unit size.
device(config-router-mpls-lsp-tunnel1)# ipmtu 1500
packet-size variable specifies the maximum packet size in bytes for IP packets transiting the LSP without being fragmented.
The following example configures a maximum IP packet size of 1500 bytes for LSP
tunnel1.
device# configure terminal
