RSVP bundle messages are disabled by default for all interfaces. To enable bundle messages on an interface, complete the following steps.
device# configure
device(config)# router mpls
device(config-router-mpls)# mpls-interface ethernet 0/13
device(config-router-mpls-eth-0/13)# rsvp
device(config-router-mpls-eth-0/13-rsvp)# refresh-reduction bundle-message bundle-send-delay 20
The bundle-send-delay option specifies the maximum period (in milliseconds) that an outgoing message can be delayed in order to create a multi-message bundle before sending. This delay is retained for the interface even when bundle messages are disabled.
The following example enables RSVP bundle messages on interface 0/13 with q bundle-send-delay of 20 milliseconds.
device# configure device(config)# router mpls device(config-router-mpls)# mpls-interface ethernet 0/13 device(config-router-mpls-eth-0/13)# rsvp device(config-router-mpls-eth-0/13-rsvp)# refresh-reduction bundle-message bundle-send-delay 20
When the RSVP neighbor does not support refresh reduction, the interface does not bundle messages even when bundle messages are locally enabled. Use the no version of the command to disable RSVP bundle messages on this interface.
Summary refresh is a more effective tool for RSVP refresh message overhead reduction.
