Apply Current Route
Compare the current route with the received label mappings and install any downstream mappings, as appropriate.
Current Route
Current next hop info for a FEC. The current route may not be applied immediately to the current label mapping as a result of LWD at ingress.
Downstream mapping (DM)
Represents the label mapping received from a downstream peer for a FEC.
FEC
Forwarding Equivalency Class. Each FEC is a destination IP address for an LDP tunnel.
LDP
Label Distribution Protocol.
Label mapping
LDP message that indicates the label to be used for an FEC from the peer.
LSP
Label Switched Path.
LWD
Label Withdrawal Delay.
Route event
Update from the routing table to LDP.
Upstream Mapping
Represents the label mapping sent to an upstream peer for a FEC.
