Enter global configuration
mode.
device# configure terminal
Configure the QoS traffic
class-to-CoS mutation map.
device(config)# qos map traffic-class-cos CoSMap
SLX(traffic-class-cos-CoSMap)# map traffic-class 0 to cos 1
SLX(traffic-class-cos-CoSMap)# map traffic-class 5 to cos 4
SLX(traffic-class-cos-CoSMap)# map traffic-class 6 to cos 4
SLX(traffic-class-cos-CoSMap)# map traffic-class 7 to cos 3
If the QoS CoS mutation map is
not configured, then the default CoS mutation map is used with 1:1 mapping for
the traffic class-to-PCP values.
Return to privileged exec mode.
Verify the configuration.
device# show qos maps traffic-class-cos
Traffic Class-to-Cos Mutation map 'CoSMap'
TrafficClass: 0 1 2 3 4 5 6 7
Out-Cos: 1 1 2 3 4 4 4 3
Enabled on the following interfaces:
Save the
running-config file to the
startup-config file.
Traffic class-to-CoS mutation map configuration example
device(config)# qos map traffic-class-cos CoSMap 3
device(traffic-class-cos-CoSMap)# map traffic-class 0 to cos 1 4
device(traffic-class-cos-CoSMap)# map traffic-class 5 to cos 4 5
device(traffic-class-cos-CoSMap)# map traffic-class 6 to cos 4 6
device(traffic-class-cos-CoSMap)# map traffic-class 7 to cos
device(config)# exit
