		  Enter global configuration mode.
device# configure terminal
		  Create and name a QoS DSCP-to-traffic class map.
device(config)# qos map dscp-traffic-class dscpTcMap
		  Define the QoS DSCP-to-traffic class values.
device(config-dscp-traffic-class-dscpTcMap)# map dscp 10 to traffic-class 3
device(config-dscp-traffic-class-dscpTcMap)# map dscp 40 to traffic-class 4
device(config-dscp-traffic-class-dscpTcMap)# map dscp 45 to traffic-class 5
device(config-dscp-traffic-class-dscpTcMap)# map dscp 52 to traffic-class 3
		   The default value is used for those DSCP that are not explicitly defined.
		  Return to privileged exec mode.
device(config-dscp-traffic-class-dscpTcMap)# end
		  Verify the configuration.
device# show qos maps dscp-traffic-class
Dscp-to-Traffic-Class map 'dscpTcMap'
{x/y: traffic-class = x, drop-precedence = y & dscp = d1d2}
d1 :  d2  0   1   2   3   4   5   6   7   8   9
0 :     0/0 0/0 0/0 0/0 0/0 0/0 0/0 0/0 4/2 1/0
1 :     1/0 1/0 1/0 1/0 1/0 1/0 2/0 2/0 2/0 2/0
2 :     2/0 2/0 2/0 2/0 3/0 3/0 3/0 3/0 3/0 3/0
3 :     3/0 3/0 4/0 4/0 4/0 4/0 4/0 4/0 4/0 4/0
4 :     5/0 5/0 5/0 5/0 5/0 5/0 5/0 5/0 6/0 6/0
5 :     6/0 6/0 6/0 6/0 6/0 6/0 7/0 7/0 7/0 7/0
6 :     7/0 7/0 7/0 7/0
   Enabled on the following interfaces:
		  Save the
			 running-config file to the
			 startup-config file.
	  QoS DSCP-to-traffic class and drop precedence map configuration example
