  1. Enter global configuration mode.
    device# configure terminal
  2. Set the TM CPU port shaper on slot 0 to 4000 Kbps with a burst size of 1KB.
    device(config)# qos cpu slot 0 port shaper rate 4000 burst 1
  3. Return to privileged exec mode,
    device(config)# exit
  4. Verify the configuration.
    device# show run qos cpu
  5. Save the configuration.
QoS for control traffic configuration example
