		 On the device, queues are provided to buffer traffic levels that exceed the bandwidth of individual ports. For each output port, a set of eight priority queues is allocated. When traffic exceeds the bandwidth of a port, packets are dropped randomly as long as the congestion persists. Under these conditions, traffic of greater priority can be dropped instead of traffic with a lesser priority.
		 Instead of being subject to random selection,
				you can configure a device to monitor traffic congestion and drop packets according
				to a WRED algorithm. This algorithm enables the system to detect the onset of
				congestion and take corrective action. In practice, WRED causes a device to start
				dropping packets as traffic in the device starts to back up. WRED provides various
				control points that can be configured to change a system's reaction to congestion.
				The following variables are used when calculating whether to drop or forward
				packets:
					- Queue-Size—The user-configurable queue size.
					- Current-Q-Size—The current size of the queue as calculated on the device.
					- Min-Q-Threshold—The queue threshold in percentage below which all packets
						are accepted. This variable is user configurable.
					- Max-Q-Threshold—The queue threshold in percentage above which all packets
						are dropped. This variable is user configurable.
					- Drop-Probability—The maximum drop probability when the Queue-Size is at
						Max-Q-Threshold. This variable is user configurable.
