Configuring Hardware Buffer for Lossless Traffic
Two QoS hardware profiles are provided to enable/disable support for buffer allocation. Select the lossy hardware profile to disable this feature. If you execute any PFC/Pause related commands, they will throw error messages. Select the lossless profile to enable this feature. PFC/Pause configurations can now be applied to the selected interface.
  1. Enter configuration mode.
    device# configure terminal
  2. Enter the hardware context.
    device# hardware
  3. Use the following command to use the lossless profile.
    device(hardware)# profile qos ?
    Possible completions:
      lossless   set qos hardware lossless profile
      lossy      set qos hardware lossy profile
    device(hardware)# profile qos lossless
    device(hardware)#
  4. Return to privileged exec mode.
    device(hardware)# exit
  5. Save the configuration.
  6. To view the PFC/Pause statistics, use the show qos flowcontrol stats command.
    device# show qos flowcontrol stats interface eth 0/1
    Interface Ethernet 0/1
                                    TX              RX
        PAUSE Frames:           565856          441122
        PFC Pri0   Frames:      565856          441122
        PFC Pri1   Frames:      565856          441122
        PFC Pri2   Frames:      565856          441122
        PFC Pri3   Frames:      565856          441122
        PFC Pri4   Frames:      565856          441122
        PFC Pri5   Frames:      565856          441122
        PFC Pri6   Frames:      565856          441122
        PFC Pri7   Frames:      565856          441122
