An MPLS QoS traffic class-to-EXP map is configured.
  1. Enter global configuration mode.
    device# configure terminal
  2. Apply an MPLS QoS traffic class-to-EXP mutation map globally.
    device(config)# qos-mpls map-apply traffic-class-exp TcExpMap all
  3. Return to privileged exec mode
    device(config)# end
  4. Verify the configuration.
    device# show qos-mpls maps traffic-class-exp
    traffic-class-cos map    'TcExpMap' (Drop-Precedence = dp)
     dp: traffic-class  :  0  1  2  3  4  5  6  7
     0: exp             :  7  6  2  3  3  2  2  1
     1:                 :  0  1  2  3  4  5  6  7
     2:                 :  0  1  2  3  4  5  6  7
     3:                 :  0  1  2  3  4  5  6  7
    Enabled on the following slots:
  5. Save the configuration.
Apply a MPLS QoS traffic class-to-EXP mutation map globally configuration example
device(config)# end
