PFC defines each one of the eight different types of flows that can be subject to flow control. In the case of an Layer 2 network, PFC uses the priority bits within the VLAN tag (IEEE 802.1p) to differentiate up to eight types of flows that can be subject to flow control, each one independently.
PFC can be configured only at the interface level.
PFC is supported only on Extreme 8720, Extreme 8520, SLX 9250, and SLX 9150 devices. For more information, see Supported Hardware.device# configure terminal
device(config)# interface ethernet 0/1
device(conf-eth-0/1)# qos flowcontrol pfc 2 tx on rx on
device(conf-eth-0/1)# end
show qos flowcontrol interface ethernet 0/1
Interface Ethernet 0/1
Mode PFC
TX frames
RX 0 frames
       TX   TX    RX   RX Output Paused
CoS Admin Oper Admin Oper  512 BitTimes
  0   Off  Off   Off  Off
  1   Off  Off   Off  Off
  2    On   On    On   On
  3   Off  Off   Off  Off
  4   Off  Off   Off  Off
  5   Off  Off   Off  Off
  6   Off  Off   Off  Off
  7   Off  Off   Off  Off
This example summarizes the commands in this procedure.
device# configure terminal device(config)# interface ethernet 0/1 device(conf-eth-0/1)# qos flowcontrol pfc 2 tx on rx on device(conf-eth-0/1)# end device# show qos flowcontrol interface ethernet 0/1 device# copy running-config startup-config
