Use an ingress or egress policy map that has been created and populated with policing parameters.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enter interface configuration mode
     device(config)# interface ethernet 2/2
  3. Attach an input or output policy map.
     device(conf-if-eth-2/2)# service-policy out policy_2
    For rate limiting ingress traffic just replace the out keyword with in and use an ingress policy map.
  4. Return to privileged EXEC mode.
     device(conf-if-eth-2/2)# end
  5. Verify the configuration.
     device# show policy-map interface ethernet 2/2 out
    Egress Direction :
     Policy-Map policy_2
        Class default
          Police cir 4000000 cbs 50000 eir 800000 ebs 400000
            Stats:
              Operational cir:4006912 cbs:50000 eir:0 ebs:400000
              Conform Byte:0 Exceed Byte:0 Violate Byte:0
    Egress policer is not supported on the SLX 9150/Extreme 8520 device. The police command affects only the CIR.
Port-based traffic policing configuration example
