A rate limit policy map is configured and then applied to the type of QoS flow defined by the class map.
		  Enter global configuration mode.
device# configure terminal
		  Create and name a policy map.
device(config)# policy-map policyMap1
		  Return to privileged EXEC mode.
device(config-policymap)# end
		  Verify the configuration
device# show policy-map
Number of policy maps : 2
Policy-Map policy
  Bound To:None
Policy-Map policyMap1
  Bound To:None
				Display policy map details.
device# show policy-map detail policy
Policy-Map policy
   Class cmap1
     Police cir 43454
 Bound To: ET  1/33(in), Te 5/33(out)
		  Save the
			 running-config file to the
			 startup-config file.
	 Policy map configuration example
