You have configured an extended Layer 3 UDP ACL.
		  Enter global configuration mode.
device# configure terminal
		   Create a class map.
device(config)# class-map aclFilter
		   The class map is used to classify the traffic; different match conditions, including an ACL, can be used to match the traffic properties.
		   While in class map mode, associate the class map with an ACL.
device(config)# match access-group acl1
		   Return to privileged EXEC mode.
device(config-classmap)# end
		   Verify the class map to ACL association.
device# show running-config class-map aclFilter
 class-map aclFilter
		   Create a policy map with a policer.
device(config)# policy-map policyAclFilter
		   A policy map is used to apply policer and QoS attributes to a particular interface.
		  Associate a class map with the policy map.
device(config-policymap)# class aclFilter
		   Each policy map can have different class maps. Each class map in the policy map can be associated to separate policing and QoS parameters.
				 Populate the class map policer
					parameters.
device(config-policymap-class)# police cir 220000 cbs 50000 eir 36000 ebs 400000
				CIR and EIR are in increments
					of 22000 bps.
device(config-policymap-class-police)# end
		   Verify the configuration.
device# show policy-map detail policyAclFilter
Policy-Map policyAclFilter
    Class aclFilter
      Police cir 220000 cbs 50000 eir 36000 ebs 400000
  Bound To:None
		  Enter interface configuration mode.
device(config)# interface ethernet 1/2
		   Bind the policy map to the port.
device(conf-if-eth-1/2)# service-policy in policyAclFilter
2015/04/02-14:13:31, [SSMD-1405], 2511, SW/device | Active | DCE, INFO, device, IPv4 access list
acl1 configured on interface Ethernet 1/2 at Ingress by FbQos_9_11.
device(conf-if-eth-1/2)# end
 Class aclFilter
 Bound To: Et 1/2(in)
		  Save the configuration.
	 ACL-based protection against UDP flood attacks applied to an interface configuration example
