Enhanced Transmission Selection (ETS) is a transmission selection algorithm (TSA) that is specified by IEEE 802.1Qaz draft standard. It defines priority-based processing and bandwidth allocation on different traffic classes with different traffic types (such as LAN, SAN, IPC).
ETS enables the switch/router to prioritize traffic based on CoS to Priority mapping. ETS enables you to configure the ETS/CEE (Converged Enhanced Ethernet) parameters. These parameters include mapping of incoming priorities (traffic with different CoS) to traffic-classes, assigning weights and corresponding bandwidth to those priorities, and scheduling of all occupied traffic-class traffic egress wire.
These settings are applied as a policy. This policy, the CEE Map, is then applied on the target interfaces. CEE maps can be applied to Layer 2 interfaces (physical switch interfaces), Layer 2 Port-channels, MCT Client Interfaces, and ICL Links. CEE maps cannot be applied to Physical or Logical Layer 3 interfaces and Tunnel interfaces.
For Enhanced Transmission Selection to work, QoS hardware profile must be configured for Lossless Profile. Do the following to set the hardware profile to the lossless profile. To enable the Lossless Profile, we need to reboot the setup.
device# configure terminal
device(config)# hardware
device(config-hardware)# profile qos lossless
                device(config)# cee-map default
                device(config-cee-map-default)# priority-group-table 15.0 pfc off
device(config-cee-map-default)# priority-group-table 15.1 pfc off
device(config-cee-map-default)# priority-group-table 15.2 pfc off
device(config-cee-map-default)# priority-group-table 15.3 pfc off
device(config-cee-map-default)# priority-group-table 15.7 pfc off
                PFC cannot be configured for Strict Priority Group traffic. Trying to configure PFC will result in an error.
device(config-cee-map-default)# priority-group-table 1 weight 40 pfc on
device(config-cee-map-default)# priority-group-table 2 weight 60 pfc off
                Only create entries for those DWRR priorities that you plan to use. Do not create entries for those priorities which you do not intend to use and assign a weight of 0 to them. For example, this is an invalid configuration.
device(config-cee-map-default)# priority-group-table 3 weight 0 pfc off
                device(config-cee-map-default)# priority-table 2 2 2 1 2 2 2 15.0
                Each entry in the row represents a CoS. In this mapping CoS 0-2, 4-6 are mapped with priority group 2. Priority group 2 is configured with 60% bandwidth allocation and PFC off. CoS 3 is mapped to Priority group 1. Priority group 1 is configured with 40% bandwidth allocation with PFC on. CoS 7 is assigned 15.0 indicating Strict Priority group.
In scenarios where Hybrid scheduling is used, the packets with Strict Priority Group traffic classes are served first. The remaining bandwidth, if any, is then allocated to the active DWRR queues according to the ratio of the weights allocated to them.
CoS 7 is reserved for Strict Priority Group and is always assigned a value of 15.0.device(config-cee-map-default)# exit
device(config)#
                device(config)# interface Ethernet 0/1
device(conf-if-eth-0/1)# cee default
                device(config)# do show cee maps default
CEE Map 'default'
Precedence: 1
Priority Group Table
1: Weight 40, PFC Enabled, BW% 40
2: Weight 60, PFC Disabled, BW% 60
15.0: PFC Disabled
15.1: PFC Disabled
15.2: PFC Disabled
15.3: PFC Disabled
15.4: PFC Disabled
15.5: PFC Disabled
15.6: PFC Disabled
15.7: PFC Disabled
Priority Table
CoS: 0 1 2 3 4 5 6 7
PGID: 2 2 2 1 2 2 2 15.0
Enabled on the following interfaces:
Ethernet 0/1
                SLX# show qos interface ethernet  0/1
[Note: CoS = Class of Service, TC = Traffic Class, DP = Drop Precedence]
Interface Ethernet 0/1
  Provisioning Mode: cee
  CEE Map: default
  Default TC: 0
  TC-to-CoS Map: default
              In-TC: 0  1  2  3  4  5  6  7
      Out-CoS(DP=0): 0  1  2  3  4  5  6  7
      Out-CoS(DP=1): 0  1  2  3  4  5  6  7
      Out-CoS(DP=2): 0  1  2  3  4  5  6  7
      Out-CoS(DP=3): 0  1  2  3  4  5  6  7
  TC-to-DSCP Map: default
      Out-DSCP(DP=0): 00  08  16  24  32  40  48  56
      Out-DSCP(DP=1): 00  08  16  24  32  40  48  56
      Out-DSCP(DP=2): 00  08  16  24  32  40  48  56
      Out-DSCP(DP=3): 00  08  16  24  32  40  48  56
  DSCP Mutation Map: default (DSCP = d1d2)
      d1 :  d2 0  1  2  3  4  5  6  7  8  9
       0 :    00 01 02 03 04 05 06 07 08 09
       1 :    10 11 12 13 14 15 16 17 18 19
       2 :    20 21 22 23 24 25 26 27 28 29
       3 :    30 31 32 33 34 35 36 37 38 39
       4 :    40 41 42 43 44 45 46 47 48 49
       5 :    50 51 52 53 54 55 56 57 58 59
       6 :    60 61 62 63
  DSCP-to-TC Map: _default_cee_dscp_tc (x/y: TC = x, DP = y, DSCP = d1d2)
       0 :     1/0 1/0 1/0 1/0 1/0 1/0 1/0 1/0 0/0 0/0
       1 :     0/0 0/0 0/0 0/0 0/0 0/0 2/0 2/0 2/0 2/0
       2 :     2/0 2/0 2/0 2/0 3/0 3/0 3/0 3/0 3/0 3/0
       3 :     3/0 3/0 4/0 4/0 4/0 4/0 4/0 4/0 4/0 4/0
       4 :     5/0 5/0 5/0 5/0 5/0 5/0 5/0 5/0 6/0 6/0
       5 :     6/0 6/0 6/0 6/0 6/0 6/0 7/0 7/0 7/0 7/0
       6 :     7/0 7/0 7/0 7/0
  DSCP-to-CoS Map: default (DSCP = d1d2)
       0 :    00 00 00 00 00 00 00 00 01 01
       1 :    01 01 01 01 01 01 02 02 02 02
       2 :    02 02 02 02 03 03 03 03 03 03
       3 :    03 03 04 04 04 04 04 04 04 04
       4 :    05 05 05 05 05 05 05 05 06 06
       5 :    06 06 06 06 06 06 07 07 07 07
       6 :    07 07 07 07
  Per Traffic-Class Tail Drop Threshold (bytes)
             TC:      0      1      2      3      4      5      6      7
      Threshold:      0      0      0      0      0      0      0      0
  Flow control mode PFC
      CoS3 TX on, RX on
  Traffic Class Scheduler configured for 1 Strict Priority queues
      TrafficClass:   0   1   2   3   4   5   6   7
        DWRRWeight:   0   0   0  40   0   0  60 ---
