On a 10G card, you can increase the rate from 300 Mbps to 13 Gbps. On a 100G card, you can increase the rate from 300 Mbps to 130 Gbps. The maximum speed supported by an interface is 130% of the default interface speed.
If you configured a breakout connector on an Ethernet interface, you can also increase the egress throughput rate on a breakout port. For Extreme 8720, Extreme 8520, SLX 9250, and SLX 9150 platforms, supported drop precedence are 0, 1, and 2.
This feature is supported only on devices based on Extreme 8820, SLX 9740, SLX 9640, and SLX 9540.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enter interface configuration mode.
    device(config)# interface Ethernet 1/2
  3. Increase the egress throughput rate on the port.
    device(conf-if-eth-1/2)# qos port-speed-up 300000
    In this example, the egress throughput rate on the port is increased by 300 Mbps.
  4. Return to privileged EXEC mode.
    device(conf-if-eth-1/2)# end
  5. Save the running-config file to the startup-config file.
The following example summarizes the commands in this procedure.
device(config)# interface ethernet 1/2
