Class Maps
The port-based rate limit, applied with the default class map, is applicable to all traffic and can be used for ingress and egress service policies. Port-based policing is only implemented to match any criteria.
You can use an IP standard or extended ACL to classify traffic for ingress-only service policies. You can use an ACL for match criteria.
Follow these rules when configuring class maps:
