								 Command  |
								 How to use for CoPP  |
								 ip icmp-fragment enable  |
								 Drop ICMP fragment packets before they are used by hackers for Denial of Service (DoS) attacks.  |
								 ip option disable  |
								 Discard IP packets with options before hackers send such packets to initiate DoS attacks.  |
								 ip access-list extended class-map match access-group policy-map  |
								 Configure rate limiting actions. For more information, see CoPP Rate Limiting.  |
								 ip access-list extended ip receive access-group ipv6 access-list extended ipv6 receive access-group  |
								 Permit or deny unicast and multicast control packets. For more information, see CoPP Discard and Permit for Control Packets.  |
								 Command  |
								 show access-list receive  |
								 See the configuration for permit and deny rules for control plan protection.  |
								 show statistics access-list  |
								 See statistics for packets that meet the permit and deny rules configured for control plane protection.  |
								 show policy-map control-plane  |
								 See the configuration of the policy map attached to a control plane interface.  |
								 show interface ethernet inc rate  |
								 See whether the control plane is receiving packets at the configured rate.  |
								 show qos cpu info show qos cpu cfg  |
								 CPU ports that allow packets into the control plane have limited bandwidth. View the maximum CPU rates and weighted fair queue values for the various VOQ groups.  |
