A policy map has been configured.
  1. Enter global configuration mode.
    device# configure terminal
  2. Access interface configuration mode.
    device(config-policymap-class)# interface ethernet 1/49
  3. Bind the ingress policy map policy map to the interface.
    device(conf-if-eth-1/49)# service-policy in policy_1
  4. Return to privileged EXEC mode.
    device(conf-if-eth-1/49)# end
  5. Verify the configuration.
    device# show policy-map
    Number of policy maps : 2
    Policy-Map policy_1
      Bound To: Et 1/49(in)
  6. Save the running-config file to the startup-config file.
QoS policing rate on an interface configuration example
