		  Enter global configuration mode.
			 device# configure terminal
		   Bind the policy map to inbound traffic.
			 device(config)# qos service-policy in policyMap1
		  You cannot use a policy map that is bound to class maps, default, or CEE maps.
		   Return to privileged EXEC mode.
			 device(config-service-policy-in/policyMap1)# end
		  Verify the configuration.
			 device# show policy-map detail policyMap1
Policy-Map policyMap1
    Class class_1
      Police cir 40000 cbs 5000 eir 40000 ebs 3000 conform-tc 6 exceed-tc 2 conform-dscp 61 exceed-dscp 63
  Bound To: none
		  Save the
			 running-config file to the
			 startup-config file.
		This example summarizes the commands in this
				procedure.
