A QoS DSCP-to-CoS mutation map has been configured.
		  Enter global configuration mode.
device# configure terminal
		  Enter interface configuration mode.
device(config)# interface ethernet 1/5
		  Enable the DSCP mutation map on the interface.
device(conf-if-eth-1/5)# qos dscp-cos dscpCosMap
		  Return to privileged EXEC mode.
device(conf-if-eth-1/5)# end
		  Verify the configuration.
device#  show qos maps dscp-cos
Dscp-to-CoS map 'dscpCosMap' (dscp= d1d2)
d1 :  d2 0  1  2  3  4  5  6  7  8  9
0 :     00 00 00 00 00 00 00 00 01 01
1 :     01 01 01 01 01 01 02 02 02 02
2 :     02 02 02 04 03 03 03 03 03 03
3 :     03 03 04 04 04 04 04 04 04 04
4 :     05 05 05 05 05 05 05 05 06 06
5 :     06 06 06 06 06 06 07 07 07 07
6 :     07 07 07 07
   Enabled on the following interfaces: Eth 1/5
		  Save the
			 running-config file to the
			 startup-config file.
	 Applying a QoS DSCP-to-CoS mutation map to an interface configuration example
