  1. Enter global configuration mode.
    device# configure terminal
  2. Create a policy map and enter policy map configuration mode.
    device(config)# policy-map policy_1
  3. Under policy map configuration mode, attach the classification map to the policy map.
    device(config-policymap)# class default
  4. Set the QoS action.
    device(config-policymap-class)# police cir 40000
  5. Return to privileged EXEC mode.
    device(config-policymap-class)# end
  6. Verify the configuration.
    device#  show policy-map detail policy_1
    Policy-Map P1
        Class default
          Police cir 40000
      Bound To:None
  7. Save the running-config file to the startup-config file.
QoS policing rate configuration example
