This feature is supported only on devices based on Extreme 8820, SLX 9740, SLX 9640, and SLX 9540.
  1. Access global configuration mode.
    device# configure terminal
  2. Access interface configuration mode.
    device(config)# interface ethernet 0/2
  3. Use the traffic class to set parameters for unicast packet handling on the interface.
    device(conf-if-eth-0/2)# qos rx-queue unicast traffic-class 3 min-queue-size 128 max-queue-size 1024
    This example sets the values for the traffic class value, with a range of 0 through 7; minimum queue size, with a range of 0 through 1024 KB per-second (KBps); and the maximum queue size, with a range of 0 through 2048 MB per-second (MBps).
  4. Use the traffic class to set parameters for multicast packet handling on the interface.
    1. Configure multicast data best effort rate.
      device(conf-if-eth-0/2)# qos rx-queue multicast best-effort-rate 3000
      The range of values is from 0 through 600000000 kilobits per-second (kbps).
    2. Configure multicast data guarantee rate.
      device(conf-if-eth-0/2)# qos rx-queue multicast guarantee-rate 30000
      The range of values is from 0 through 600000000 kbps.
    3. Set parameter values, by traffic class, for multicast packet handling on the interface.
      device(conf-if-eth-0/2)# qos rx-queue multicast traffic-class 3 min-queue-size 512 max-queue-size 1024
  5. Return to privileged EXEC mode.
    device(conf-if-eth-0/2)# end
  6. Verify the configuration.
    device# show qos rx-queue interface all
    device# show running-config | include queue
    qos rx-queue queue-size 512
  7. View the buffer pool statistics.
    device# show buffmgr stats slot 0
  8. Save the running-config file to the startup-config file.
This example summarizes the commands in this procedure.
