		  Enter global configuration mode.
device# configure terminal
		   Select the policy map.
device(config)# policy-map policy_1
		  Select the classification.
device(config-policymap)# class default
		  Specify the scheduling attributes.
device(config-policymap-class)# scheduler strict-priority 3 dwrr 10 10 10 10 60 TC535000 TC6 36000 TC7 37000
		  Return to privileged EXEC mode.
device(config-policymap-class)# end
				Verify the configuration.
device# show running-config | include strict-priority
  scheduler strict-priority 3 dwrr 10 10 10 10 60 TC5 40000 TC6 41000 TC7 42000
				Enter interface configuration
					mode.
device(config)# interface ethernet 0/1
				Bind the policy to the port.
					device(conf-if-e-0/1)# service-policy out policy_1
device(conf-if-e-0/1)# end
		  Save the
			 running-config file to the
			 startup-config file.
	 Strict priority scheduling configuration example
