The following actions must be completed.
  • A QoS DSCP-to traffic class map must been configured.
  • For Extreme 8720, Extreme 8520, SLX 9250, and SLX 9150 devices, a Layer 2 switch port needs that the qos trust dscp be enabled before applying the qos dscp-to-traffic class map.
    Similarly, on the Layer 2 switch port qos trust dscp cannot be disabled before removing the qos dscp-to-traffic class map.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enter interface configuration mode.
    device(config)# interface ethernet 1/2
  3. Activate the QoS DSCP-to-traffic class mutation map on the interface.
    device(conf-if-eth-1/2)# qos dscp-traffic-class dscpTcMap
  4. Return to privileged EXEC mode.
    device(conf-if-eth-1/2)# end
  5. Verify the configuration
    device# show qos maps dscp-traffic-class
    Dscp-to-Traffic-Class map 'dscpTcMap'
    {x/y: traffic-class = x, drop-precedence = y & dscp = d1d2}
    d1 :  d2  0   1   2   3   4   5   6   7   8   9
    0 :     0/0 0/0 0/0 0/0 0/0 0/0 0/0 0/0 4/2 1/0
    1 :     1/0 1/0 1/0 1/0 1/0 1/0 2/0 2/0 2/0 2/0
    2 :     2/0 2/0 2/0 2/0 3/0 3/0 3/0 3/0 3/0 3/0
    3 :     3/0 3/0 4/0 4/0 4/0 4/0 4/0 4/0 4/0 4/0
    4 :     5/0 5/0 5/0 5/0 5/0 5/0 5/0 5/0 6/0 6/0
    5 :     6/0 6/0 6/0 6/0 6/0 6/0 7/0 7/0 7/0 7/0
    6 :     7/0 7/0 7/0 7/0
       Enabled on the following interfaces: Eth 1/2
  6. Save the running-config file to the startup-config file.
Applying a QoS DSCP-to-traffic class map to an interface configuration example
