		  Enter configuration mode.
device# configure terminal
		  Create a WRED profile identified as profile 1, set the thresholds, and set the drop probability.
device(config)# qos red-profile 1 min-threshold 30 max-threshold 60 drop-probability 44
		  Verify the WRED configuration.
device(config)# do show qos red profiles 1
Red Profile 1
        Minimum Threshold: 30
        Maximum Threshold: 60
        Drop Probability: 44
		  Return to privileged exec mode.
		  Save the configuration.
	 WRED configuration example
device(config)# exit
