Table 1. Map parameters for rate limiting in SLX 9540
Parameter Values Range Increments of
cir - Committed information rate bits per second 22000 through 300000000000 Starts at 22000 then is rounded up to next achievable rate.
cbs - Committed burst size Bytes per second 1250 through 37500000000 1 Byte
eir - Excess information rate bits per second 22000 through 300000000000 Starts at 22000 then is rounded up to next achievable rate.
ebs - Excess burst size Bytes per second 1250 through 37500000000 1 Byte
The parameters cir and eir are configured in bits per second, cbs and ebs are configured in Bytes per second.
The possible combinations when entering policer values are:
device(config-policymap-class)# police cir 600000000
device(config-policymap-class)# police cir 700000000 cbs 8000000000
device(config-policymap-class)# police cir 7000000000 cbs 70000000 eir 500000000
device(config-policymap-class)# police cir 7000000000 cbs 70000000 eir 500000000 ebs 90000000
device(config-policymap-class)# police cir 700000 eir 800000
device(config-policymap-class)# police cir 700000 eir 800000 ebs 6000000
Follow these rules when configuring the class map policier parameters:
  • The CIR value must be specified; all other parameters are optional.
  • You should configure the rate (CIR/EIR) and burst size (CBS/EBS) based on the interface speed.
  • Default values will be calculated if not specified by the user.
  • Configured values take priority over default values.
  • If you only specify the CIR value, a default value is calculated and set to CBS value.
  • If you specify the values of both CIR and CBS, the configured value takes priority over the default values in the policer.
  • Should the CIR value be updated, the configured CBS value is retained, and the default value is not restored.
  • If you want to revert to the default CBS value, you must first remove the configured CBS value.
  • To disable the learning of MAC addresses for stream matching of the ACL-based rate limiting entries, the CIR and EIR values must be 0.
    The MAC address entries in the MAC-address table which are already learnt are not be flushed when you configure the CIR or EIR value as 0. You must explicitly clear the entries in MAC-address table by using the clear mac-address-table dynamic command.
