Egress QoS Mutation
The QoS operation on egress traffic involves
marking packets as they leave the chip on the egress port. As the packets are prepared
to exit the device you can set the PCP, DSCP, and CoS values in the packet headers.
Egress QoS mutation does not apply to
SLX 9150/
Extreme 8520
devices.
- 802.1P priority mapping (traffic class-to-PCP mutation)
- The internal traffic class can be mapped to the outgoing PCP value when the
packet egresses the switch. You can create a priority mapping table using a CoS
mutation map. This CoS mutation map can then be applied to an egress interface
to effect the priority re-mapping. This feature only maps the internal traffic
class to outgoing priority.
- DSCP remarking
- This feature allows the user to remark the DSCP value of the egressing IP packet
using the ingress DSCP value. The configuration must be bound to an egress
interface.
- DSCP-to-CoS mutation mapping
- The ingress DSCP value can be mapped to outgoing 802.1P values by configuring a
DSCP-to-CoS mutation map on the egress interface.
