The Wireless Controller, Access Points and Convergence Software system now support get and set for a number of proprietary MIBs that are listed below. By using the Netsight Suite and the following MIBs, you can configure the controller to create and manage policy, VNS (Virtual Networks Service), VLAN (Virtual LAN); backup and restore configurations.
Use these MIBs to perform controller hardware and software resets, including backing up and restoring controller configurations via the NetSight Suite. SNMP (Simple Network Management Protocol) must be enabled on the controller for NetSight Suite integration.
For more information on NetSight suite integration, see the User Guide.
