The following figure displays back panel features of the C5215. C5215 Back Panel Features depicts the features and functions of the C5215 back panel.
| Callout | Feature | Function |
| 1 | AC Power Supply 1 | AC Power Supply 1 and 2 combine to make a redundant power supply. |
| 2 | AC Power Supply 2 | |
| 3 | 1GbE RJ45 | Management port – eth0 |
| 4 | Port 2 | Not used, plugged |
| 5 | Video Connector | Used to see POST BIOS information during controller boot up |
| 6 | RJ45 Serial-A Port | Console Port – Used to get into Rescue mode. |
| 7 | USB Ports | Connects USB 2.0 and 3.0-compliant devices to the system. For more information, see the Note below. |
| 8 | RMM4 NIC Port | Not used, plugged |
| 9 | Data Port 1 | 1GbE RJ45(esa0) |
| 10 | Data Port 2 | 1GbE RJ45(esa1) |
| 11 | Data Port 3 | 1/10GbE SFP+(esa2) |
| 12 | Data Port 4 | 1/10GbE SFP+(esa3) |
