Mounting a Flash Device on the Wireless
Controller
To mount a flash device on the
controller:
From the top menu, click
Controller.
From the left pane, click
Click Mount, and then click OK to confirm the flash
device mount. Once the mounting process is complete, the flash memory space is
displayed and the files contained on the flash device are listed in the Available Files box.
When you mount
the flash device, the F icon in the footer changes from red to green.
If a flash device was already mounted (previously inserted),
the screen shows the status as Mounted as well as all available files on the flash
device.
