Downloading the Remote Image File to the Local Drive or USB Device
To download the Remote Image
File to the local drive or USB device:
From the top menu, click
Controller.
From the left pane, click
Select Remote.
The FTP/SCP server boxes are
displayed.
Type the following:
- Protocol – FTP or
SCP.
- Server – The IP address of
the server to retrieve the image file from.
- User ID – The user ID used
to log into the server.
- Password – The password for
the user ID.
- Confirm – The password to
log on to the server. This field is to confirm you have typed the correct
password.
- Directory – The directory
on the server in which the image file that is to be retrieved is stored.
- Filename – The name of the
image file to retrieve.
In the Destination drop-down list, click Local or Flash to specify where the image is downloaded to.
Click Get Image now.
The
Download
Image window is displayed, providing the status and results of the
download. The image is downloaded onto your system and added to the
Select upgrade list.
SCP can only be used
to download an image and cannot be used to start remote upgrade. The Upgrade now
button is disabled when SCP is selected from the drop-down list.
