Deleting a Software Image
It is OK to delete a software image if it is no longer needed on your system.
To delete a software upgrade:
  1. From the top menu, click Controller.
  2. From the left pane, click Administration > Software Maintenance.
  3. In the Select upgrade list, click the software upgrade you want to delete.
  4. Click Delete selected.
  5. In the dialog box that is displayed, click OK to confirm the deletion of the upgrade. The Software Maintenance window is displayed, providing the status and results of the deletion.
