Backing up the wireless controller database and creating a software package backup are two different processes. Backing up the wireless database only involves creating a backup of specific content in the wireless database. For example, you can choose to backup configuration, logs, or audit information. To create a backup image of your operating system, use the backup and restore functionality of the system.
Configuration data for the wireless controller is saved in NVRAM (non-volatile memory).When you backup the wireless database, you can choose to do the following:
V2110 (MS Hyper-V platform) does not support flash functionality.
