Resetting Your System Configuration
To reset your system
configuration:
From the top menu, click
Controller.
From the left pane, click
In the Reset Configuration section, select the appropriate configuration reset options:
- Remove installed license – The system reboots and restores all aspects of the system configuration to the initial settings and the license key is removed. However, the Management IP address is preserved. This permits administrators to remain connected through the Management interface.
- Remove management port configuration – The system reboots and resets the entire system configuration to the factory shipping state. The Management IP address reverts to 192.168.10.1.
Click Reset Configuration.
- Depending on the configuration reset options you
select, a warning message is displayed asking you to confirm your selection.
- If the Remove installed license option is
selected, the warning message also displays the license activation key and
optional features license keys.
Warning
Copy the license key information displayed in the warning
message in order to reuse these keys after the controller resets to its factory
defaults.
The system reboots and the configuration is reset to its factory
defaults.
