Working with an External Storage Device
V2110 (MS Hyper-V platform) does not support flash functionality (upgrade, backup, restore, storage, etc.).
You can use a USB device to do the following maintenance tasks:
The USB device is automatically made available to the GUI/CLI (mounted) by the controller when inserted in the device slot. After the flash device is mounted, the GUI/CLI shows the content of the flash device for the related operation, such as backup and upgrade. To manually unmount or remount an already inserted flash device, use the controller GUI:
Flash Device File System Format
All flash devices used with the controller must be formatted in FAT32. Only the first partition of the flash device is used by the controller.
Controller software can operate (backup, restore, delete, etc.) only with files located in the root directory on the flash drives. In other words, it cannot operate with files located under directories.
Wireles controllers equipped with multiple USB connectors support only one USB device at a time, regardless of what USB connector the device is connected to. If you connect a second USB device while the first is already connected, the system will return an error.
Warning
Warning
Ensure all flash devices used with the controller are formatted to be non-bootable. Otherwise, the controller may experience difficulties when rebooting if connected to a bootable formatted flash device.
