Backing Up the Current Image During the Upgrade Process from the Wireless Assistant GUI
You must follow the procedures detailed in this section if you want to backup the current image via the Wireless Assistant GUI while upgrading the image. For more information on how to upgrade the image, see Upgrading Using the GUI.
When you backup the current image, the license activation key and option keys are also backed up.
