Downloading a Backup File
You can download an existing backup file from a server using FTP (file transfer protocol) or SCP (secure copy protocol), or from flash to local storage.
To download an existing backup
from a server using the GUI:
From the top menu, click
Controller.
From the left pane, click
Click the Restore tab.
Select a Remote under Copy Backup File From.
Enter values for the following:
- Protocol — Select the file transfer protocol you want to use to download the backup file (SCP or FTP).
- Server — Type the IP address of the server from which the backup will be downloaded.
The Server parameter supports both IPv4 and IPv6 addresses.
- User ID — Type the user ID
used to log into the server.
- Password — Type the
corresponding password for the user ID.
- Confirm — Type the
corresponding password for the user ID to confirm it was typed correctly.
- Directory — Type the
directory on the server where the backup file is stored.
- Filename — Enter the name
of the backup file you want to download.
- Destination — Define
whether a file is transferred to local or flash from a remote server.
Click Copy.
The Software
Maintenance window is displayed, providing the status and results of
the download.
from a server using the CLI:
Log into the system using SSH or console.
Download the backup file
from the FTP or SCP server using the following command:
EWC.extremenetworks.com#copy configuration (to-local | to-flash | to-remote
serveruser
dir [ftp
password | scp
password]) (from-local
filename|number | from-flash
filename|number | from-remote
server
user
dir
file [ftp
password | scp
password])
For example, to
download the backup file EWC.03122009.071327.zip locally
from an SCP server:
EWC.extremenetworks.com#copy configuration to-local from-remote 192.168.3.10 test conf_bak_dir
EWC.03122009.071327.zip scp abc123
The command
will download the file and store in the local storage.
To see all
backup files stored in the local storage, use the show import command.
EWC.extremenetworks.com#show import
1: EWC.03122009.071327.zip
To copy an
existing backup from a flash to local storage using the GUI:
Controller.
The Wireless Controller Configuration screen is
displayed.
The EWC
Software tab is displayed.
Select a source Flash under Copy Backup File From. Flash has to be mounted for this.
In the Filename drop-down list, click the backup you want to transfer.
Click Copy.
The Software Maintenance window is displayed, providing the status and
results of the operation. The local backup copy is going to be displayed in Available
Backups list as well.
To copy an existing backup
from a flash to local storage using the CLI:
Copy the backup file from
the local storage to flash using the following command: EWC.extremenetworks.com#copy configuration (to-local | to-flash | to-remote
serveruser
dir [ftp
password | scp
server
user
dir
file [ftp
password | scp
password])
For example, to
copy the backup file BAK.03122009.071327.zip locally from a flash:
EWC.extremenetworks.com#copy configuration to-local from-flash BAK.03122009.071327.zip
To see all
backup files stored locally and on flash, use the show import command.
1: BAK.03122009.071327.zip
2: BAK.03122009.071327.zip(flash)
