| Field Name | Field Description |
| In the Capture Locations pane, configure the following settings: | |
| Wired | Enables wired-packet capture on the selected AP. Filter packets on the basis of the direction of packet flow:
Select Includes Wired Clients to include wired-packets received and transmitted to and from wired clients associated with the selected AP. This option is disabled by default. |
| Wireless | Enables wireless-packet capture on the selected AP. Filter packets on the basis of the direction of packet flow:
Specify the radio interface on which to enable
wireless-packet capture.
Note: You have the option to capture wired and
wireless packets simultaneously. The result is two PCAP files: one displays wired
packet information, one displays wireless packet information.
| In the Settings pane, specify how you want to determine the length of the packet capture. Options are: Maximum Packet Count, Duration, or manually end packet capture by clicking Stop. | |
| Maximum Packet Count | Specify the maximum number of packets captured and logged
to the PACP file. The default value is 50000. Packet capture stops once the threshold
specified here is reached, unless manually stopped. Note: The
default maximum packet capture data limit is 1 GB. Therefore, regardless of the
Maximum Packet Capture Count specified, packet capture stops once the PCAP file size
reaches 1 GB.
| Duration | Packet transfer window. Default value is 5 minutes. |
| In the Filter pane, filter packets by MAC
address, IP address, IP Protocol, or Port. The filters are mutually exclusive and are
applied in the order in which they are listed. Enter at least on MAC address or IP
address. Note: Excessive packet capture degrades network
performance. If you are going to enable packet capture on all APs, specify at least
one MAC address filter and one IP address filter to avoid performance
degradation.
| Filter by MAC 1 and Filter by MAC 2 | Specify one or two MAC addresses to filter packets for capture. When a MAC address is specified, only packets that move to and from the specified MAC addresses are captured. |
| Filter by IP 1 to Filter by IP 4 | Specify one to four IP addresses to filter packets for capture. filters. When an IP address is specified, only packets that move to and from the specified IP addresses are captured. Both IPv4 and IPv6 address formats are supported. |
| IP Protocol | Specify the protocol to filter for packet capture. Packets
matching the specified protocol are captured. Valid values are:
| Port | Specify a TCP or UDP port number. Packets with the matching port number are captured. Use Port as an additional filter, or if you wish to specify a protocol that is not included in the IP Protocol menu. |
| Export |
and wireless packets simultaneously. The result is two PCAP files: one displays
wired packet information, one displays wireless packet information.
