To get into Rescue mode, you must connect your laptop to the controller‘s console port using a Serial RJ45 to DB9 Female cable.
If your laptop has a USB port instead of a serial port, you must use the USB 2.0 to RS232 Serial Adapter to connect the RJ45 to DB9 cable to the laptop.
Print
this page
Email this topic
Feedback
