C5210 Back Panel Features
C5210 Back Panel Features displays back panel features of the C5210. C5210 Back Panel Features depicts the features and functions of the C5210 back panel.
Graphics/C5210_back-2.png
Callout Feature Function
A AC Power Supply 1 AC Power Supply 1 and 2 combine to make a redundant power supply.
B AC Power Supply 2
C 1GbE RJ45 Management port – eth0
D 1GbE RJ45 Data port 1 – esa0
E 1GbE RJ45 Data port 2 – esa1
F Port 4 Not used
G Video Connector Used to see POST BIOS information during controller boot up
H Serial-A Port RJ45 Console Port – Used to get into Rescue mode.
I USB Ports Connects USB 2.0-compliant devices to the system. For more information, see the Note below.
J RMM4 NIC Port Not used, plugged
K 1/10GbE SFP+ Data port 4 – esa3
L 1/10GbE SFP+ Data port 3 – esa2
M Expansion slots. Not used
N Chassis tab Used for optional cable bracket.
The C5210 is equipped with 5 USB connectors — 2 on the front panel and 3 on the back panel. However, the controller is capable of supporting only one USB device at a time, regardless of what USB connector the device is connected to. If you connect a second USB device while the first is already connected, the system will return an error.
