The figure below depicts the chassis front panel of the C35. C35 System Status LEDs describes the C35 system status LED functions.
| 1 | System Status LEDs | 5 | USB Port |
| 2 | LCD Panel | 6 | Console Port |
| 3 | Not Used | 7 | Reset Switch |
| 4 | Ethernet Ports (see C35 Ethernet Ports) |
| 1 | Data Port 1: 1GbE (esa0) | 4 | Data Port 4: 1GbE (esa3) |
| 2 | Data Port 2: 1GbE (esa1) | 5 | Mgmt Port: 1GbE (eth0) |
| 3 | Data Port 3: 1GbE (esa2) | 6 | Not used, plugged |
| LED | Function |
Power: When this LED is on, it indicates power is supplied to the WS-C35 power supply unit. This LED should be illuminated when the system is operating |
Status: When lit Green, it indicates operational state is normal. When lit Red, it indicates a system malfunction. |
Hardisk (HDD): When this LED flashes, it indicates hard drive activity. Otherwise, the LED remains off. |
