The C5110 comes with an optional front panel bezel (see Attaching the Bezel to the Font of the C5110), which can be attached to the front of the chassis by snapping it on the chassis handles. A key lock allows you to lock the bezel in place so that the controls on the front panel cannot be used. You can monitor the system status indicators with the bezel in place.
| 1 | Key lock | 2 | Bezel cover |
