Copying AP Logs
  1. From the AP Log Management dialog, click Copy AP Logs to transfer locally collected logs. The Copy AP Logs dialog is displayed.
    Graphics/copy_ap_logs_dialog.png
  2. Set the location of the AP Logs by selecting either Remote or Flash. The Flash button is disabled when flash is not mounted.
  3. When Remote is selected, do the following:
    • Under Protocol, select SCP or FTP to select the file transfer protocol you want to use to upload the AP Log file.
    • Under Server, type the IP address of the server where the AP Logs will be uploaded.
    • Under User ID, enter the user ID used to log into the server.
    • Under Password, enter the corresponding password for the user ID.
    • Under Confirm, enter the corresponding password for the user ID to confirm it was typed correctly.
    • Under Directory, enter the directory on the server where the AP Log file will be stored.
  4. Click Copy to copy the logs.
