All wireless APs have a reset button, but they are located in different places on the AP chassis. Use it to reset the AP to its factory default settings by pressing and holding the reset button for at least six seconds.
If you press the reset button and do not hold it longer than six seconds, the wireless AP simply reboots, and does not reset to its factory defaults.The AP installation documentation is available at: https://extranet.extremenetworks.com/downloads
Print
this page
Email this topic
Feedback
