Opening the C5110
Removing the Cover from the C5110
Graphics/1950_remove_cover.png
1 Latch 3 Alignment J hooks
2 Latch release lock 4 Chassis tabs
  1. Turn off the system and attached peripherals, and disconnect the system from the electrical outlet and peripherals.
  2. Remove the bezel.
  3. To remove the system cover, rotate the latch release lock on the latch in a counterclockwise direction to the unlocked position (see Removing the Cover from the C5110).
  4. Lift up on the latch on top of the system to guide it back and into an offset position (see Removing the Cover from the C5110).
  5. Grasp the cover on both sides and carefully lift the cover away from the system.
