Deleting Files from a Flash Device
To delete files from a flash device:
  1. From the top menu, click Controller.
  2. From the left pane, click Administration > Flash.
    The Flash Memory screen is displayed. The mounted flash memory space is displayed and the Available Files box displays any files located on the flash device.
    Deleting Files
    Graphics/flash_mounted2.png
  3. In the Available Files box, click the file you want to delete, and then click Delete.
  4. To confirm the file deletion from the flash device, click OK. The file is deleted.
