The rescue image resides on the wireless controller‘s hard disk in a separate partition called the rescue partition; the running software image is stored in the normal mode partition.
You can restore the rescue partition in the rare event that it becomes unavailable or corrupted (for example, because of a hardware disk hardware error or a power failure during upgrade). To restore the rescue partition, you must obtain a healthy rescue image and install it on the wireless controller.
A healthy rescue image is available from one of the following locations:
Rescue Image File Naming Conventions
| Wireless Appliance Model | Rescue File Extension |
| C5110 | .rtxe |
| C5210 | .rrue |
| C5215 | .rice |
| C4110 | .rgxe |
| C25 | .rpfe |
| C35 | .rcwe |
| V2110 (VmWare platform) | .rbge |
| V2110 (MS Hyper-V platform) | .rize |
Use the restore procedure in an emergency only when the rescue partition is not accessible. Restore commands are available in the CLI to administrators only; these commands are not listed when you enter the help command.To restore the rescue image:
EWC.extremenetworks.com# show restore-rescue 1: rescue.rrue
If a rescue image exists, go to step 3; if no rescue images exist, skip to step 5.
For example, to restore from the locally saved rescue image, rescue.rrue, enter the command:
EWC.extremenetworks.com# restore-rescue local rescue.rrue
For example, to download the rescue image for the C5210 model controller from the FTP site and, as the user admin with the password abc123, install the rescue image, AC-MV-09.01.01.0183-1.rrue, into the store directory, enter the following command:
EWC.extremenetworks.com# restore-rescue ftp 1.1.1.1 admin abc123 store/ AC-MV-09.01.01.0183-1.rrue
