The ExtremeSwitching series switches use a mechanism different from the earlier ExtremeSwitching series to implement ACLs. The same
architecture and guidelines apply to both
platforms.
Instead of the per port masks used in earlier switches, these
platforms use slices that can apply to any of the supported ports.
An ACL applied to a port may be supported by any of the slices.
The slice support is as follows:
ExtremeSwitching X450-G2
switches—
Each group
of 48 ports has 4 slices with each slice having enough memory for 256
egress rules, which adds up to 1024 rules.
Each group of 48 ports
has 16 slices with each slice having enough memory for 256 ingress
rules, which adds up to 4,096 ingress rules.
ExtremeSwitching X460-G2
switches—
Each group
egress rules, which adds up to 1,024 rules.
has 16 slices with each slice having enough memory for 256 ingress rules
ExtremeSwitching X440-G2 switches—
Each group of 24 ports
has 4 slices with each slice having enough memory for 128 egress rules,
which adds up to 512 rules.
has 8 slices with each slice having enough memory for 256 ingress rules,
which adds up to 2,048 ingress rules.
ExtremeSwitching X465 switches—
Four slices of 256 egress
rules, for a total of 1,024 rules.
has up to 12 slices with a total capacity of 8K single-wide rules
ingress rules.
