The IP and MAC anycast feature enables you to configure the anycast gateway
MAC to be used by VLANs that enable IP anycast. Using this feature, you can set the same
IP address and MAC address on all edge technology devices. This allows seamless IP
mobility in the network for edge devices.
IP and MAC anycast should be used
only with VXLAN tenant VLANs. IP and MAC anycast should not be used with any
protocols other than MLAG, since it might cause MAC flaps.
Switching through a VXLAN tunnel to a
remote L3 Anycast gateway is not supported.
To configure IP/MAC anycast:
Enable IP anycast on the desired
VLANs by using the following command:
enable ipanycast {vlan} vlan_name
Specify the anycast gateway MAC
address that is used by VLANs that enable IP anycast by using the following
command:
configure ipanycastmac [none | mac]
To specify that configured secondary IP addresses respond to ARP
requests with the anycast MAC address, use the following command and specify the
anycast option:
